Cutting Poly. Sheet
OLD
9 Aug 2004
Nantwich Cheshire
Is there a tool for cutting polystyrene sheet 50mm which produces a good edge and minimal clean up. A hot wire would seem to fit the bill but where to get one or how to make ,however you may have better suggestions.
Incidently its to insulate the flat roof in the work shop 16" ctrs. 3x2
DemiFrog
15 Sep 2004
France
Hi OLD,
In the past I have used a craft knife with a new blade fully extended out, I then proceeded to cut the polystyrene slowly and carefully.
Aragorn
6 Feb 2004
East Sussex
A bread knife is what I use. As John suggests, I think a serrated blade is the way to go... Unless you get the hot wire thing working, of course!
johnb
22 Oct 2004
Vosges, France
Cut across the width of the sheet with a sharp knife. That way, if it snaps, you have a good edge most of the way through.
