Crosscutting thin strips
fraser
8 Nov 2010
Isle of Wight
Hi
I need to accurately cross cut some thin strips from a 12" wide board. I only have the bosch gts 10 to do this and I wondered if anyone could either tell me the best way to do this, or point me in the direction of an article or other thread that would tell me. Preferably keeping my fingers full length...
Any help would be great
Thank you
baldpate
30 Jan 2011
London
You could buy yourself the Kreg Square-Cut saw guide (not very expensive) which is designed precisely to aid accurate cross-cutting of boards up to 12" wide. Or you could make something similar easily enough - the principle is very straightforward - but it's hardly worth the time it considering how cheap the Kreg is.
Chems
23 Apr 2008
A Wood Haven
baldpate
30 Jan 2011
London
fraser says he wants to cross-cut the board - have I misunderstood?
Chems
23 Apr 2008
A Wood Haven
No I don't think you have. The kreg tool is essentially the same outcome as a guide rail, just different ways to get there.
Tony Spear
6 Apr 2006
Hinton Waldrist
12" long strips entirely of end grain.
Depending on how thick (or thin!) they are, aren't they likely to snap or even crumble when handled? :?
custard
20 Aug 2008
Hampshire
Fraser, can't really help you on this but here's something to think about for the future. I'm in the process of shutting up my London workshop and moving to Lymington, just across the Solent from you. The new workshop should be up and running in the autumn. So if you're in a similar position then let me know whenever you're passing and we'll whizz it through a bigger machine.
marcros
11 Feb 2011
Leeds
looks a handy jig. Like an Incra fence but on a much smaller/cheaper scale for a specific task.
brihol
30 Dec 2008
Enfield
I've read this thread several times and am not sure whether you have your answer yet. You've told us what tablesaw you have and immediately people suggest using some other tools. What is the problem with crosscutting at the moment? Is it the accuracy of the fence, the difficulty of pushing the cut wood through without it launching backwards ...? It's the sort of job where a home made cross-cut sled would be invaluable.
Brian
fraser
8 Nov 2010
Isle of Wight
The jist of it basically revolves around the fact there is no stop to pull your timber against whilst pushing it through to crosscut. at the moment, I am working to pencil lines and cutting as close as I can. Obviously this is not accurate. It seems most other mitre gauges that you can buy, kreg and others, are made to fit what I understand is a more universal track, 19mm, so these aren't suitable.
brihol
30 Dec 2008
Enfield
Could you use your mitre fence and rip fence with a sub-fence (say, a piece of 2x1) attached to the back part which releases the cut wood just after the cut begins and thereby prevents jams and kickbacks.
Brian
andersonec
25 Jun 2010
Lincolnshire
Brian
Brian, I was thinking exactly the same, we have here a table saw quite capable of making very accurate repeatable cuts either with a quick made one off sled specifically for the job but if you have a nice table saw then why not make a decent cross-cut sled because I can guarantee that it will be used over and over, it is one of my most used aids and to get it to cut exactly square check how this guy sets it up. http://www.thewoodwhisperer.com/videos/ ... -cut-sled/
If this route is not to be taken then the table saw must have come supplied with a mitre gauge, screw a strip of wood the gauge to carry the work forward square to the blade and clamp a stop to the table saw on the other side of the blade to the thickness you want, slide your work across to meet the stop and bob's your uncle, so they say, you have strips cut to exactly the same length.
Andy
