Grahamshed":1xzh8hxj said:
The common use seems to be to slop it on all over and denib before putting on a second coat. The sealer itself can be waxed or polished up as a finished product if desired.
I have also read that each coat should be sanded until the surface layer is totally removed and it is only left filling the pores, the resultant bare wood can then be waxed to produce a more even coating.
You can't generalise about sealer.
There are too many variables, not least type of sealer, Cellulose, Shellac, Acrylic for starters, which have their own drying and hardening timescales resultant from the solvent used.
Then there are the wood species that provide varying structure densities per species and even within a specific piece.
Because I'm an impatient individual as far as finishing is concerned and am happy with the 'shine' level it produces without a deep in depth gloss I stick with cellulose sealer for 90% of my pieces.
For speed I keep my 'user' sealer in a screw topped jar containing an application brush and dilute it 10-20%.
I sand to 240-320 grit, paying particular attention to grain direction and slap on a coat of sealer and wipe off surplus to see if it highlights any scratches or torn grain spots missed in sanding or perhaps the odd spot that has soaked up all the sealer with no shiny skin on the surface.
If scratches, blemishes or dull spots are detected they are re-sanded if necessary and locally re-coated.
If all ok pieces are three wheel buffed as soon as lathe is setup for process.
Same procedure is used for Shellac, Acrylic or lacquer if used but timescale is considerably extended by hours or days to allow sealer coat to harden before buffing.
What is the best way to use it ?
The way you find appropriate for the type of turnings you do and that give you the finish you prefer. Experiment and see what you like, in six months you will probably change your mind and do it differently but by that time you will know why you are changing.
