Copy of full PC Installation
AndyBoyd
22 Nov 2002
Heiloo The Netherlands
Chaps
I´ve just spent hours after putting a new hard disk in my laptop, re/installing all my software XP, SP2 and all it´s updates etc etc
Is there a neat way to take a copy of your system set up and write that to a CD-DVD so I could load all everything in one go, should I need to?
Here's hoping
Andy,
There are quite a few back up solutions available - you need to clone the disk not just copy the files. When I was on a PC, I used Acronis True Image which usually worked pretty well. ( http://www.acronis.com/enterprise/produ ... trueimage/ ).
You are right to do this before the disk gets cluttered up again, it makes a successful restore much more likely.
You need to do something called ghosting, buy a ghosting programme, very cheap.
Ghost your existing hard disk onto a cd or dvd depending on amount of data.
Install new hard disk.
Copy ghosted cd or dvd onto new h.d.
Or alternately wait for Argee, who knows what he's talking about :) , but I'm pretty sure the above will work.
Dom
There is also the Files and Settings Transfer Wizard in Windoze that may do what you want.
Hi
I would re-enforce Chris' opinion with Acronis it is very well respected, and I do know someone who has to restore in anger with it and it worked fine. I use it and the interface is dead easy. The same person had previously had a bit of grief with Norton ghost which apparently has taken a turn for the worse since version 8.
Cheers Alan
Andy,
I use Acronis True Image too - a fair bit. Don't bother with any of the fancy features and it works fine. They were giving away the older version (7 IIRC) free - someone mentioned it here. But I can't find the link ...
Gidon
Acronis true image 7....for free ;)
Code:
http://www.flexbeta.net/main/comments.php?shownews=21786&catid=5
Hope this works ok.
I would just like to add that Acronis is very good and used it too myself :)
