Steve Maskery
Ladies and Gentlemain, as Frankie Howerd might have said, no, look, listen, here.
I've designed this 'ere chair:
The way I have drawn it, the back is only 12mm thick. I could beef up the lower part so that it is 20mm thick or so at floor level, but that still means 16mm max at seat level. My problem is obvious, how on earth do I attach the rails to the back?
This is the joint that gets most strain, but I'm not at all convinced that a tenon that is only 12-16mm long would be sufficient.
This is a bedroom chair, not a dining chair so the back won't be seen like a dining chair back would, so if I have to use brass caps it won't be the end of the world, but I'd prefer not to have to use them, I'd like to do some reasonably trad joinery here if possible.
These are the sort of things I mean from Woodfit:
I have seen chairs built with laminated backs like this before, but I've no idea what joinery the makers used. Anyone have any expertise in this area? It will be a lot of work to get wrong!
Steve
Steve
