Clamping two/three polished surfaces together..
MCTWoodwork
10 Apr 2020
Somerset
Hi there,
This piece of furniture I made & designed whilst on my course at Rowden Atelier in Devon a few years back - I never finished it, but I finally insulated a small workshop last year (at home) to finally complete this piece I designed.
I was really after some advice from you wonderful people (!) with regards to clamping polished surfaces. The surfaces will be shellac & waxed (aka part French polished) so require delicate handling & then all clamped together. I'm really after some tips from you experts out there please - someone must have done this before, surely??
I'll domino the 'hats' together for alignment purposes but don't want the clamps to ruin the polish. I could put them together first and then polish afterwards but this can be very tricky getting the polish right over multiple surfaces. I wish i could afford to send this off to a finisher... i don't know about you, but i really hate finishing!!
See the 3D cad design attached & the photo of the cabinet (doors just hung - unpolished!) so you know what i mean...
Thanks in advance.. :)
Matthew
Hi Matthew, it looks fairly straightforward to me. You need 2 cauls made from mdf or similar, cut to size, and possibly padded with a bit of old blanket or whatever. The main issue is going to be getting them all aligned properly- are you dowelling them or similar?
Crikey, that’s not a piece you can ignore is it !
Sorry to disagree with you Peter but I think if you use material it may imprint the weave into the top surface I would use something like formica / bit of old worktop perhaps. Ian
Hi Pete,
Pete,
Hi Pete, thanks for your reply & the information - although, I'm just not sure that might still leave an impression using cloth? I'll use domino's for alignment purposes.
Regards,
Matthew
So you reckon the polish (once fully cured) won't be damaged by the work top / formica pressing down on the two surfaces?
Can’t think of any reason why it should, as long as you don’t pick a worktop that has a texture to it of course, that other suggestion of using a few sheets of paper that was a good one as well. Ian
if the weave impression is left on the polish then the polish isn't very fresh. also I wouldn't stress to much as it could be easily fixed.
Cheers Ian, and thanks to everyone's help & suggestions. :)
