Circular saw blade questions
grahame
25 Nov 2010
Angus
I bought a s/h Triton saw + workcentre
The Triton 235mm blade has one tooth broken off
Is it possible/worth it to get this repaired/resharpened?
It had a 25-16mm bush
I have a nearly new blade on a DeWalt which is 230mm
Is it OK to use this smaller blade on the Triton?
If it is, I need a 30-16mm bush
Can I buy this separately?
Or is it easier to buy another general purpose blade which already has bush supplied?
Which brands are good value?
yes it is possible to get it repaired but the cost may be too high for the value of the balde.
contact your local saw doctor.....I can guide you if needs be....
Yes you can use the 230 mm blade 9you lose 2.5 mm of cut height)
yes you can buy a bush seperately....again local saw doc may have one cheap.
a 24 tooth 230 mm shouldnt cost anymore than £25 including bush, delivery and VAT
