Richard Findley
gnu":ugloj3md said:Do you worry about the underside of your tv set, sofa, car or fridge when you buy it? Probably not. So why should you worry about the undersides of you bowls as long as it is neat and tidy. Whether it has screw holes or a recess is not liklely to put the customers off. In fact if you leave the recess on the customer can bring it back that beautiful cherry fruit bowl a few years to be polished up or if it has got damaged it can be remounted and skimmed.
I've been thinking about this statement. The underside of my sofa is neatly upholstered with piece of fabric across the base, just so it is nicely finished off. The underside of a TV has 4 little rubber feet, positioned so it sits level and safely, it may also have some vents to allow air flow. I can go on if you like....
The point is, everything has a bottom and you can leave it rough but all that does is show low standards and a lack of design. A well finished bottom raises your bowl above the rest and is so easy and cheap to do, I see no reason not to.
Just my opinion.
Richard
