CHJ / powertool
Blister
UKW Supporter
10 Nov 2006
Boston Lincs
Hi gents
Any chance when you do your next turning you can do a set of work in progress photos for us new chips on the block ??
would help out so we can see if it looks the same as ours " before it finished
Its nice to see the finished items as well
:p :p
Yes of course,but it might be the weekend.
As long as you are aware that I am an enthusiastic amateur,and am in awe at the work produced by several other forum members :D
Andrew
Made it into the workshop this afternoon,after spending a couple of hours this morning precariously balanced up a stepladder changing a toilet cistern :shock:
So here's a few work-in-progress type pictures :-
Blank mounted on a faceplate ring with 16mm screws
Then mounted on the lathe,and made a little more round
Chucking recess made
Base shaped
Power sanded (dry) with 120 grit
Then wet sanded (with wax,as this was to be the finish) by hand to 400 grit,and waxed
Turned round,and the wall thickness and depth set with a parting tool
Inside shaped with the trusty bowl gouge
Again,power sanded with 120 grit
And wet sanded to 400 grit and waxed
Finished article :-
Oak,150mm diameter,20mm overall height
Andrew
powertool, thats a nice little bowl. many thanks for shareing it with us newbies. now ive got a couple of tools i can start to do somthing in the morning :roll:
I'll see if I can take some WIP photos as well next time I'm out - hopefully tomorrow. I've also got a load of finished turnings waiting to be photoed when I can be bothered...
Duncan
Andrew
Thanks Andy that was really useful. If you feel in awe imagine what us newbies feel like. I was looking at Mark Hancocks site the other day when I was looking for inspiration.....have I got a long way to go.
No need to bother with a face plate ring Pete.
I tend to use a large, sat 1 1/2" sawtooth bit in the drill press and sink a hole 3 to 5 mm deep to mount on the chuck dovetail jaws initially. You can also then bring the tailstock up for some extra support initially if required until the piece is better balanced.
Alternatively, just mount the blank straight on a screw chuck, or even just between centres, and then turn your chucking recess before reversing the piece onto the chuck jaws.
Lots of different ways of getting there........!
Cheers, Paul. :D
Thanks PowerTool
Looks simple enough , but I know its not :?
Nice bowl
when you say wet sanded with wax , how do you do that ? does it not fly of all over the place ? or do you do it at a slow speed ?
Forgot to say that doesn't need to be a chucking recess of course, sometimes better to be a spigot, and can be turned whilst on the screw chuck or between centres.......
Cheers, Paul. :D
I still sometimes resort to using a paper joint with a scrap block if the wood I want to turn is thin - for anyone who's never used this ...
put a dovetail matching your jaws on a scrap block of wood and flatten the other face
sandwich a piece of paper of card between the 2 pieces of wood and glue using pva,
allow the pva to dry
mount the scrap block in the jaws and turn your final profile including a chuck mount of your choice
reverse the piece in the chuck
prise apart the glue joint using a chisel - do this across the grain
continue as normal
Glue blocks can be re-used so it's useful to keep a few handy
I'll try to get some photos next time I do it
Duncan
Duncan
I tried that and.......flying saucers!!!
I wasn't using flour and water, honest. I was using hot glue
I always sand at the lowest speed on the lathe (500 rpm on mine) - the idea is to let the abrasive do the work; going too fast will burn and polish,rather than abrade.
Wet sanding involves a light coating with paste wax (if you are going to finish with wax) or oil,and sanded through the grits to a finish; this keeps the dust down when sanding,and creates a light slurry which effectively becomes a grain filler.
This of course only works for timber where the sapwood and heartwood are similar in colour - not a great idea for laburnum :wink:
Andrew
Me too....Wait 'til you see the stuff in his workshop :D
Andrew..that was a really great series of 'How To' pictures.
Andrew,
A great demonstration. I too am curious about the "wet sanding". I often finish with oil. Presumably I can therefore wipe on a coat of oil before starting on the fine sanding (once tool marks gone?). Does the abrasive not just get all clogged up? Do I need to use wet and dry paper? Presumably it would be wise to cover the bed of the lathe for this part?
Cheers,
Dod
Yes,exactly as you said - light coat of oil when the toolmarks have gone.The abrasive does clog up more,but it is this slurry that becomes the grain filler.
I tend to do a very light coat between each grit,and sand until you can just about get dust off it again.
And there is no need to use wet-and-dry (but also,no reason why you can't) - ordinary abrasives are fine; when round to fine finishing,it also works well with webrax/nyweb.
I read about this technique in a book by Mark Baker,and think he learnt it off Ray Keys,so although this is how I happen to do it,like all things you need to find what works best for you. (In the same way as Chisel said,although I happen to use a faceplate ring and short screws for thin pieces,there are several other ways to achieve the same thing)
Happy turning :D
Andrew
speanwoody":39f8sefi said:
dare I put this link on for another chat site that has online videos http://www.turnwood.net/videos.html, also if you type woodturning in to http://www.youtube.com/ you can see some video clips there
The first link won't work as it is, you'll need to type it in without the '/videos.html' part then use their link. You can also download these videos. I have a few that are useful, at least to us newbies.
