First and most important, it only takes one psychologists to change a light bulb.
BUT zeeee light boolb hass reeely got to vant to change 8) 8)
Secondly, Bob (a bit out of left field here?) here is the break down of the 'watch' and it really does fit on my wrist. A bit alkward and ostentatious, but it fits :mrgreen:
The pins are turned from box and the trickiest bit was to drill the hole through the top of the strap for the long pin that not only holds the outer part of the buckle, but also the buckle center pin. That pin is only about 1/16" diametre, as are the others. The watch body is beech, the strap is cherry and the buckle is mahogony. Lastly, the clock insert is Axy :mrgreen: :mrgreen:
The frightening thing is that I got 4 of the clocks, so 3 more to make sometime :shock: :shock: :shock:
Sorry Bob, I have just re-read your post
The 'sticky out bits' for the straps were cut out on my band saw after the recess for the clock was turned and then sanded down to the final shape. It really is quite fun to make and the fact that it will actually fit on my wrist was quite a surprise and not intended. I only tried it to a friend to show off 8)
