Random Orbital Bob
What's industry standard height for the seat of a chair folks ie floor to bit your rear rests on? I'm getting anywhere from 17" to 20" on those in my home. Wondered if there's a standard at all?
450- 460 mm (~18") is pretty standard. The standard varies a bit, and for a custom designer maker the height of a chair seat (and other detailing such as cushioning, seat angle, etc), can be tailored for a specific individual for a specific function. But for a dining chair intended to fit a wide percentile of the population ~18", as already mentioned, is typical. The corollary is that dining table height is usually set somewhere between 250 and 300 mm (10" - 12") above seat height to provide a comfortable eating (shoulders not hunched up for example) along with enough room for the thighs if a rail between 75+ mm and ~100 mm (3" - 4") wide is included in the design.Random Orbital Bob":1abbzl1a said:What's industry standard height for the seat of a chair folks ie floor to bit your rear rests on? I'm getting anywhere from 17" to 20" on those in my home. Wondered if there's a standard at all?
I like the "Of course" bit!phil.p":273rh9vw said:Steve's point is good, of course.
phil.p":273rh9vw said:Many designs would allow you to make the chair an inch or so higher than you planned and cut them down afterwards if needed? No reason why not, and it's a damn sight easier than going in the other direction .
phil.p":3qjtvzg2 said:I once made 6 x 29.5" tables for a place that had 30" door linings. Then I realised that the doorstops were 3/8"...
No it isn't standard at all - there is no standard - it's very variable. 30 ish is common, but the opening would then be 29 ish so your 29.5 table wouldn't go anyway. Unless you did the sensible thing which would be to carry the table in sideways and weave the legs round the frame (if the hall way and the table design permits it) which means you can get a normal 4 leg table through even though it's wide and taller than the door opening widthSteve Maskery":287cue95 said:.....
It's all very well making a table that is comfortable to sit at, but you do have to get it through the door and a standard UK door width is 30". OK, these days there are other options, but is is the de facto standard in many traditional houses.
Really? News to me. They seem to come in all shapes and sizes and removal man have ways of doing things with huge pieces of furniture!So most tables were built to 29.5". ....
Jacob":1khary52 said:No it isn't standard at all - there is no standard - it's very variable. 30 ish is common, but the opening would then be 29 ish so your 29.5 table wouldn't go anyway. Unless you did the sensible thing which would be to carry the table in sideways and weave the legs round the frame (if the hall way and the table design permits it) which means you can get a normal 4 leg table through even though it's wide and taller than the door opening widthSteve Maskery":1khary52 said:.....
It's all very well making a table that is comfortable to sit at, but you do have to get it through the door and a standard UK door width is 30". OK, these days there are other options, but is is the de facto standard in many traditional houses.Really? News to me. They seem to come in all shapes and sizes and removal man have ways of doing things with huge pieces of furniture!So most tables were built to 29.5". ....
Chair height "standard" is about 18" but there are huge variations. Not surprising - people sit at all heights from floor level, cushion, smqll pouffe, stool, chair, high stool etc etc and tables may be found to match.
