CHAINSAW LATHE... what a great idea...
either that video's faked or that chainsaw is incredibly blunt - mine would have pulled itself into the wood and cut the column in half well before the end of the video
he'd be better off with a power file or a sander - or for that matter just carving it by hand
its not fake. he has other videos showing it, check them out its pretty interesting seeing the inventions of an silly person
I guess it did not dig itself into the column because the chainsaw was also spinning the column round, so the relative speed of the chain against the wood was a lot lower (which also explains why he spent 5 minutes sawing at the column to no noticeable effect)
if you watched later on in the video he shows an improvement he made, he put a bit of spring steel springing down onto the wood so it doesnt spin at as fast as the chainsaw so it chews up the wood faster
I keep asking myself 'why?' (hammer)
And the bucket of water speed control - variable with the amount of water - and sandpaper under the 'braking' arm so you can sand the work at the same time??
As Homer woudl say "D'Oh!" (homer)
