transatlantic
Boom!
Just popped for a quote from Carpet Right to get some rooms changed. What I have at the moment is bare concrete with grippers around the edge. They told me that I had to remove the grippers, and that they would be using spray adhesive.
Pretty sure the previous carpet was stuck down with both the grippers and glue (as I can see the remnants of glue around the edge of the room)
Why would they ask me to remove the grippers? (something I should have asked them but didn't think to)
Surely the grippers would provide extra 'grippage'? The reason I ask is because I use a wheelchair and want the best grip I can get as turning around on the spot tends to ripple carpets if they're not stuck down well.
Any carpet fitters here?
These are only small rooms btw. 10'x10' .. oh and with no underlay as apparently I don't need it with the carpet I have chosen. No underlay also works better with wheelchairs as you don't sink into it causing excess friction.
