Carbide cutter tips
13 Jul 2015
Wales
Am I right in thinking that carbide cutter tips are mostly used for fast stock removal? and that when you want to apply your finishing cut, you would switch to a HSS bit?
Is that why most hollowing tools come with both carbide and HSS cutter options?
MARK.B.
4 Jul 2012
East Yorkshire
I use my carbide tipped tools for everything from start to finish, the options could be due to price difference.
selectortone
Still waking up not dead in the morning
30 Dec 2015
Sunny Bournemouth by the Sea
It depends on how much sanding you are prepared to do. There are guys at my club who have been turning for 50+ years who can get a finish with a HSS or carbon steel bowl gouge that barely needs sanding. You can't do that with carbide tools, but you can get to the same end result if you don't mind making some dust.
Paul Hannaby
1 Sep 2011
Gloucestershire UK
There is more to achieving a clean cut that just the choice of metal. Sharpness, tool presentation, angle of cut and bevel (or no bevel) position all play a part.
