graduate_owner
Hi everyone, I'm mainly into woodworking, but occasionally use metalworking kit such as milling machine and lathe. I have a stick welder which is great for thick steel, say 3mm upwards, but I'm thinking about a MiG welder for thinner stuff. I suspect I would use it more than my stick welder, but mainly for thin steel or tack welding thick stuff prior to stick welding.
So, does anyone have experience of the Clarke welders that Machine Mart sell. I've been wary of Clarke stuff for a while, and most Clarke stuff I've had has been pretty poor quality. However I understand the Clarke welders are made in Italy, not Chaiwan, and are re-badged Telwin machines which have a decent reputation - so I'm told. I've also been told the wire feed motors on some of these cheap welders are better suited to cheap cassette players than welders.
As it will be for occasional use, I'm reluctant to spend more than about £200. However if £200 buys me rubbish then I'll go to perhaps £250 - £300, or alternatively stay with my stick welder.
Also, is it really expensive to weld with disposable canisters of gas, even for occasional use? Should I bite the bullet and go for the range which takes full size gas bottles?
Any opinions would be much appreciated.
K
K
