I am making up a piece of equipment and part of it is a requirement for an air-operated clamp (to hold the piece of wood in position while the operation is carried out on it). I think I only need a clamping force of around 20 lbs or maybe 10 Kg, and ideally I would be able to apply a rubber end to the piston to provide a decent grip (as the push on the wood from the tool will be at right angles to the piston).
I would like to be able to operate it with a foot control. I have a 1.5HP compressor already.
Any advice would be gratefully received.
