C: help
RogerS
20 Feb 2004
In the eternally wet North
I'm trying to clean out an old NAS file server (XP embedded) and would prefer to delete the folders etc directly from the C prompt. The Data is on the D drive but I've forgotten what the commands are. There are a load of directories. Is there a different command to delete a directory as oposed to a file?
And to override any locked files, read-only files etc?
I thought deltree would work but it says not recognised
Have you used the CD command to point to D drive?
e.g. CD D:\
Deltree should work I would have thought
deltree d:\mydirectory
Cheers :D
Tony
hi
if your using windows xp you need to go to the widows c:\ dos prompt in all programs look up accessories you should find you not at the c: prompt try cd c:\ when there try cd d:\ then typ dir *.* find the file required and do the business . hc
I have just been playing. Entering 'cmd' in the Run text box brings up cmd.exe. This works in a slightly different way to Programs - Accessories - Command Prompt. At least on my XP machine.
However. Enter 'cmd' into the Run text box.
At the promt d:
D:>
See <DIR>'s and files
D:>dir
Now I had a problem with a folder name having a space
D:>Tree Loose Apps - did not work
However
D:>Tree "Loose Apps" - did work
When I typed in
D:>DEL "Loose Apps"
I got
D:>Loose Apps\*, Are you Sure (Y/N)?
Is this what you are after?
By the way Loose Apps is just the name of the folder I was playing with, substitute as required.
xy
EDIT (after about 5 minutes)
The instructions above didn't work for me, sorry. But this did.
At the D:> prompt
D:>RMDIR "Loose Apps" - will say the folder is not empty
D:>RMDIR /s "Loose Apps" - will ask for confirmation, in my case it worked.
/s includes all subfolders.
If this does not work look at permissions.
xy
Thanks, xy....being upset by spaces was one litte gremlin that caught me out.
Will also try the help command. Long time since I used the C prompt.
If what I remember from my old DOS days (ahhh, those times of re-jigging memory allocation in config.sys/autoexec.bat, IRQ/DMA settings etc.....), then 'RD <dir_name>' should work too. Though I can't remember if you need to empty the directory first.
Also, '<command> /?' should help out with any arguments for that command.
Hope that helps, and hope I remembered correctly!
Adam S
