Buying wood advice
Steliz
Camberwell Carrot
11 Dec 2017
Hungary
I've just been down to my local wood yard to buy the Pine for a Pergola I'm about to build (I'm not in the UK so bear that in mind). I was in there last week just to get a feel for the price and I was told that all of their wood was classed as dry even though it was only cut down 2 weeks before. They don't have a kiln so drying must happen elsewhere. I was given 2 prices with a difference of ~£150 less (on almost 3m cubed) if I opted for boards that are not dry. There was some translating going on between us so I'm not 100% sure what the actual definitions of dry and not dry are.
Can anyone clarify this based on UK experience? Obviously, I want the wood to be dry enough for the purpose but will I be OK with wood described as 'not dry'? Perhaps the opportunity to save money is clouding my judgement here?
As far as I know it takes about a week to 10 days to kiln dry softwood.
Would have to be a pretty slick operation for the trees to have been felled, kiln dried and delivered to the yard in 2 weeks.
I suggest you invest in a moisture meter.
Basically, here in the UK 'dry' construction grade timber for the construction industry means wood that has been dried to 20% MC or lower. There's a bit of give allowed in the quality control for testing large batches of wood coming out of the kiln of approximately 4 percentage points. In other words, if a batch of wood comes out of the kiln followed by a representative sampling of pieces tested, and most samples read, say ~18% MC and a few read up to 24% then that batch is considered 'dry' for the purposes of strength testing and grading, the results of which are marked on the pieces.
'Dry' from a furniture maker's point of view, or anyone else making internal joinery, such as doors and other artefacts that fit within the walls of habitable buildings (rather than, say, external garden furniture) need their wood drier at somewhere between roughly 7% MC and perhaps 12 - 13% MC.
You are building a pergola, which is presumably outside, so I imagine you won't need it especially dry, all depending upon where you live, which you say is not in the UK. A good moisture content for that type of construction is likely to be anywhere between roughly 20% MC and even perhaps green, i.e., basically unseasoned, again, dependent upon where you live, and also dictated by your design, which could be anything from fairly delicate and engineered to chunky and rustic.
On the other hand, I'm not sure 'pine' is the ideal choice for a pergola because most 'pines' aren't especially durable in ground contact, so be a bit careful about which 'pine' you're buying - there are several pine species that might (or might not) be available. Alternatively, you could consider using tanalised wood, or make your pergola out of something with known natural ground contact durability, such as oak ... and you might have a pergola design that lifts your not especially durable wood (pine?) away from the ground, such as brick or block piers or a wall of some sort maybe 8" - 12" high that the sit under the wood. Slainte.
Don't forget that a pergola is going outdoors, and doesn't have to be built to the tolerances of a piece of furniture. I built my last one of green oak, completely unseasoned.
I would have preferred to use green oak but it is not available as a building material here (Hungary) and usually ends up as firewood. The vast majority of houses have wood fuelled heating here. Also, tanalised or pressure treated timber is not available at the wood yard although I've heard that the B&Q equivalent has it.
The pergola will stand on a concrete base with metal plates to keep it off the ground.
Most of the treated softwood constructional timber I buy is kiln dried but then left in a merchant's yard in all weathers - kiln-dried, yard-soaked!
As everyone else is suggesting, I'd go with the non-dried option and remember to clean and oil tools at the end of each session (as per usual?!).
Cheers, W2S
Cheers, W2S
PS I imagine you have a more continental climate there and so - as long as not in contact with the ground as Mike mentioned - your timber should last longer than if it were in the temperate/wet of most of the UK - even if untreated. I don't know what kind of rapacious insects you have there though...
