Stupid questions time ...
What's the approximate % difference in price between buying sawn and PSE (or PAR) redwood?
I'm planning to build a utilitarian cabinet in my workshop. However, rather than using plywood (which I'm more used to), I want to use it as an exercise in practicing some hand tool skills on cheap materials before I start butchering some oak for the lounge.
I already have a planer / thicknesser (there's only so much handplaning sawn stock that I could take). So would sawn be significantly cheaper?
Also, I assume that if I order 25mm sawn timber, it's approximately 25mm thick and that if I order 25mm PSE then it's more like 20mm thick (e.g. started out as 25mm) - is that right? I'm wanting most of my parts to end up approx 18mm thick - is 25mm the right starting size?
thanks all
thanks all
