The Woodpecker
Hopefully this is the right section to put this....
A little while ago i built what was going to be my workshop, complete with router table, workbenches etc.
I hadn't even finished the project when the family decided to hijack the workshop for use as a gym!
Eager to crack on with some woodwork and no room left in the garden to build another shed anyway, the only alternative was to move into an old summer house which is pretty small, 7' x 7' max and octagon shaped, so i would need to be quite creative in it's design!
To be honest, i quite like the way it's working out and i'm pleased i had to move into it but it's definitely a challenge, especially when i keep moving the goal posts....i was pretty much set to go when i decided i wanted to incorporate a bench saw into the worktop as well as the router, meaning i had to re-configure the whole layout.
I scrapped the original router table and fence i had built because i just wasn't happy with it and bought a fence instead!
I will get some pics up once i have everything installed ( i won't say completed because i will probably keep making modifications as i go) so you can get a better idea of the space i have!!!
In the meantime (and this was actually the reason i started this thread) i could do with some advice please.
I have finished the router table top/bench in MDF and wondered if i should apply a coat of varnish to it or just leave it untreated?
Thanks in advance!
Thanks in advance!
