Box or angle
GrahamIreland
4 Jun 2015
Nottingham
Hi, Im starting out and making shelves, possibly a display stand.
Was looking at other work and seeing shelves with wood inlayed.
It looks obviously neater to have wood layed under angle, but what if under neath is seen as well.
Would angle iron ever have more flat bar welded to it to hide edges on both sides...
Graham
I'd make it with angle so the wood sits on the angle and you only see the thin edge on top. Welding more flat to the top just seems overkill? Stick the wood in with some gripfill and you're away...
+1 for angle, box is a non starter for this job as you either have to fix through it to get to the wood or weld a lip or little lugs for the wood to sit on.
Try and get angle with a square root rather than rounded or you will need to chamfer the outer edge to suit.
If you're buying angle to do the shelves it makes sense to use it for the door.
Or go for channel (although that might dictate your sizes more)
Cheers guys, supplier here only has channel in 35mm I think, which is too big,
I guess angle would work fine if i was to try and replicate something like this.
Nice one, Graham
Channel for a door raises a difficult question anyway, as to how to get the timber panel inside the metal after welding (before welding not being an option).
I have seen it sold in 25mm at least, although that doesn't help you.
I would have thought, weld three corners then place inside,
maybe tack all for first, weld three then break off and place wood inside?
maybe..
It would still scorch the wood. Angle would be a lot easier than channel.
