Jacob
It's difficult to force new belt over the flanges it looks like some dismantling should be done but can't see how and don't want to break anything.
How to do it?
How to do it?
New belt will be a bit on the stiff side but a bit of force/leverage is needed. Start on the small pulley, lube the big pulley with a little F/Liquid, and slowly lever the belt on whilst rotating it, ensure belt on the small pulley doesn't ride up over the flange.Jacob":v9t7g2j8 said:It's difficult to force new belt over the flanges it looks like some dismantling should be done but can't see how and don't want to break anything.
How to do it?
Only took you 4 days..... : )Jacob":36deu5n3 said:Cracked it - dead easy no force required!
1 Take off belt cover and two small covers from top, one over the switch/handle the other at the other end over the brushes.
2 This reveals four bolts which hold the complete bottom assembly to the top.
3 Separate them and put them back together with a bit of a wiggle to get the belt over the two splined pulleys.
Nah 10 minutes! Been busy. I tried the force method first but reckon it's impossible. Maybe yours is a slightly different model?Noel":5l0zyhsd said:Only took you 4 days..... : )Jacob":5l0zyhsd said:Cracked it - dead easy no force required!
Will keep this in mind if and when next needed although the method I mentioned takes a few minutes but maybe best to do it the gentle way as you described.
