mbartlett99
I'm in the long drawn out process of building some workshop cabinets which is a first for me. Using it to build some skills (ie make lots of mistakes, learn from them and then promptly forget the lesson, make more mistakes and stomp off in a huff).
Finally approaching the finish line and need to fit some Blum hinges into the mdf. The hinges come with plastic inserts for the screws - drill an oversize hole, insert plastic dowel and then screw into the dowel/insert.
Question; when using mdf is it better to simply use the screw or to use the plastic inserts?
Thanks.
Thanks.
