Blum clip top hinge loading for wardrobe doors
sjalloq
14 Mar 2014
Cambridge
Hi there,
I'm wanting to build a set of wardrobe doors that are full 2400mm in height by 700mm wide. Has anyone got any suggestions as to how many hinges I need per door? I'm assuming that a chipboard based sheet will be the least dense and best option?
Cheers.
Thanks. I have stock of them already so was going to use them. Are there any other choices of more robust hinges? I was looking at the SOSS range but the minimum door thickness is 28mm and I was hoping to use standard 18mm sheet goods.
