Blade Holder - practical, not posh
JanetsBears
9 Feb 2015
Pontefract
After a couple of months of owning my new scroll saw, the pile of used blades sat at the side of it was growing. I've tried a number of different blades while trying to learn how to use my new saw. I'm now starting to realise that I can't remember which blade is which, especially if I've slept since last time I used the saw, so thought it was about time I made some means of storing blades that I'd used. The result is this:
The intention is that I use it purely for storage of used blades, dropping a label in each tube as I add blades, so that when I need a Pegas Number 5 Reverse Skip I can re-use one I've previously got out of the pack of new ones. I may or may not make another to hold just new blades, but that can wait. This one is made from 4mm ply and the pattern for it fitted on a single A4 sheet of paper. It took just over an hour to cut out and it's had no sanding before or after being glued - there's more to life than sanding projects that aren't ever going to leave the side of the scroll saw ;)
It's being able to quickly knock up little things like this that now makes me realise that I should have had a scroll saw years ago, but what other useful/practical stuff have you made with your scroll saw?
Chris
    223.2 KB
Very nice Chris BUT did you know you already had a rack for your test tubes? along both sides of your scrollsaw is some slots in the casing........those are for slotting your test tubes into :cool:
Scroll saws are very useful bits of kit and always something new to experiment with them, i recently tried cutting thin alloy sheet that i glued to so bendy mdf, the idea was to cut it flat and then bend the mdf to a shape and it worked ok but i couldn't think what to do with it lol looked pretty cool though and even tried flattening the alloy from a coke can (sugar free of course) and stuck it to some plywood with double sided tape and that worked well, maybe someone can come up with a use for this type of material?
glad your having fun anyway
Brian
Ah, well, if I'd bought the next size up then it would have the test tube slots, but I have plain blanking plates on mine. I have considered replacing the plates but I'm not a fan of working with thickish metal, especially when I can play with the scroll saw instead :D
Chris
Chris
Oh bugger! I thought all the Excalibur/Axminster saws had the slots :oops: my apologies :roll:
I agree with ya regarding cutting the thick metal plates apart from being tough I wouldn't want to cut a brand new saw up either.
Have fun
Brian
ps have you got any projects lined up for the new saw?
Claymore":2p7gt06d said:
...I agree with ya regarding cutting the thick metal plates apart from being tough I wouldn't want to cut a brand new saw up either.
Have fun
Brian
The side plates are simply fastened on with a bolt in each corner, so at some point I may just make a replacement (or buy one from Axminster) and modify it, keeping the original in case I ever sell it.
Projects lined up include loads more word art type stuff that various family members are demanding, but I'm constantly looking for new things to try. Made a shoe rack for my wife - was eying up one online that was going to cost about £160 but now she has a made to measure one that she's finishing at the moment and total cost was only about £30 for the wood. Only a tiny part of the job needed the scroll saw (would have been quicker with the bandsaw but it was cold in my workshop!) and the rest needed my table saw. I want to try some intarsia but I'm waiting for slightly warmer weather so I can do my sanding outside of the house. Happy to take ideas for other projects I might make to give me new things to try.
Chris
PS Wife just sent a picture, she's just got the first top coat done, I see it needs a little bit more sanding in some areas. It's going in that gap between the chair and the umbrella stand...
    223.9 KB
