piggybladder
Hello all,
I'm trying to make up some homemade 1 metre clamps using cast iron clamp heads I got from Rutlands with box aluminium for the struts. The clamps will take 25mm width so I'm planning on using 50mm x 25mm box aluminium. I've already trial built 2 prototypes using 16 gauge 40mm by 20mm box aluminium, which went okay. I marked out and punched each row of holes on each side and went through the HSS drill sizes from 3mm up to 10mm on my pillar drill. I found this to be not as accurate as it might be. A couple of holes were very slightly misaligned, which translated into a not insignificant sideways skew on the clamp heads. Mea culpa, poor marking out, drilling or unlevel table. It was also tedious having to mark out and drill both sides of the piece and having to lower my platform and re-align the table between drill changes. I'm not looking forward to doing the next 8, which will be the finished articles.
So can anyone tell me the quickest and most accurate way to drill parallel holes in aluminium? I am thinking a stepped drill bit might work better. If it is long enough to completely drill 10mm holes on the top face and partly drill through the bottom face albeit from the inside wall, then I'd only have to mark out one side and not have to change the platform height. I'd only have to flip the piece over and finish the partly drilled holes on the second face. Is this workable and accurate enough or is there a better way?
Thanks in advance.
Thanks in advance.
