• If you have bought, sold or gained information from our Classifieds, please donate to UK Workshop and give back.
    You can become a Supporting Member or just click here to donate.
Sold Festool LS-32-SYS Hole Drilling Set
Apache_sim
26 Jan 2013
Stowmarket
FOR SALE - FESTOOL LS-32-SYS .... Bargain at £250 on its own or £320 with the FS1400/2-LR 32 Rail
If you make cabinets then this is the jig for you, Accurately drill holes for shelves and rear wall supports at 32mm centres when used with the Hole Guide rail FS1400/2-LR 32 (or the longer 2424 hole rail). Also includes a 35mm (unused) hinge location cutter.
Hole series are always drilled with a spacing of 32 mm and a hole diameter of 5 mm or (3 mm bought separately). The hole series drilling system is a complete set for fast and simple production of series of holes for shelf supports, rear wall supports and fittings with the OF 900, OF 1000, OF 1010, OF 1400. Everything in a single Systainer. Note: In terms of condition it is like new apart from some light corrosion evident on the guides. Probably only use once or twice to build a cupboard or two, since then has remained unused for several years. Total cost to buy new today from Festool would be over £700.
The Systainer contains:
  • guide plate
  • centring mandrel
  • hinge location cutter HM Ø 35 mm
  • dowel drill HW Ø 5 mm (V-shaped tip)
  • dowel drill HM Ø 5 mm (with centring bit and pre-cutter)
  • 2 parallel side fences with adjustable stop
  • FSZ 120 fastening clamps (two units)
  • 2x Longitudinal stop
  • screwdriver, WAF 5
  • Systainer SYS 1 T-LOC
Providing a location can be really helpful as we can see if something for sale is within traveling distance or we might be able to assist someone as they are close by so just saying UK is not as helpful as say Suffolk or York.
