timmytiptoes
New member
A quick call for advice.
I am building a bandsaw and am looking at the wheel bearings and shafts. I have some shafting material donated by a friend. The shaft is 20 mm diameter, H6 tolerance grade.
I understand that the shaft size should be linked to the tolerance of the bearing to get the fit that you require. Is this something that I need to worry about for this project or can I just buy any 20 mm bearing and the fit will be good enough for my needs.
The shaft will be fixed with the bearing pressed in to a housing on the wheel, if that makes any difference.
Thanks for taking the time to look.
Tim
Tim
