Philly
Hi Folks
Every time I pick up a woodworking mag (well, Fine Woodworking, anyway :lol: ) there seems to be an article on cutting veneer with your bandsaw. And all these articles recommend building a high fence to make this possible.
So, during a spare minute, I used an off-cut of kitchen worktop to knock up this monstrosity.....
As you can see, it's not pretty. I added supports at the rear to keep it square and it is held onto the table with some clamps.
Having the laminate face out makes for a friction free fence. And how did it work??
Pretty well!! I cut a veneer 1.2mm thick from some 200mm tall cherry. Pretty impressed was I! I was also very impressed with the quality of the surface - the saw marks were pretty fine (as the 5p in the picture hopefully shows) The blade (a 4tpi 30mm wide one from Axminster) is pretty worn so I would expect a fresh blade to make life even better.
If you've been thinking of making a hgh fence for your bandsaw give it a go. It certainly makes cutting veneers safer and easier.
Hope this helps
Philly
Hope this helps
Philly
