Bodgers
This is my first vaguely 'proper' tablesaw. After almost getting over the fact that Axminster dropped the price on this by over £100 within a couple of weeks of buying this, I got it out of the box and set it up.
Negatives:
- I heard the pressed steel extension table wasn't up to much, but it is really bad. When I first got it out of the box, I thought "how bad could it be?". Pretty bad actually. The aluminium rails that it hangs on, and connects to the saw by, are perfectly fine and true. Problem is the actual pressed steel table - it is a joke. Basically the pressing near the edges push the corners up, resulting in a difference in height of around 10mm between the edges and the middle. There is also a support strip welded half way on the underside, which results in more unevenness. I am going to swap it out for some thick birch ply at some point.
- there are some QA issues. Large ding in the long fence, rip/ding in the blade ange guide, crushed ends on some of the dust hoses. Bit of peeling paint on the side of the cast iron, etc.
- clamping the fence down moves the end of the fence about 6-7mm out of true with the front (using the long fence) much wiggling and grabbing the fence to stop it moving whilst clamping it is needed. Although, when it is in place and square, it is reasonably solid. I have ordered the Axminster band saw fence 'upgrade' from a supplier in the US for a fraction of the cost, so will eventually fit that anyway.
- fence doesnt exactly slide nicely across the top. Manual says lubricate the tracks etc. but even after doing that it just seems to kind of judder across the top. I have applied non-silicone grease. Wouldn't it be better if it was slightly raised above the table surface when not clamped down?
- the manual could do with some work - there are parts of it with fig/diagrams/photos and no accompanying explanation.
- the mitre fence thing and/or the t-rail it runs in could do with some work. Fence is only a close fit along the top edges, on the lower edges it is pretty slack, so you end up with play if you move it in a certain direction. Some aluminium tape might solve this. It also seems fractionally tighter at the front end of the slot.
Postive:
- cast iron top is great - nice and straight, solid.
- realtively quiet.
- mine came setup very square - blade was parallel to mitre slots and riving knife. Riping a 1m long length of spruce resulted in a variance of about 0.3mm from start to end, using digital calipers - not bad for an out of the box setup.
- seems adquate on the power front. Only ripped spruce and a oak flooring for now, but it had no problem dealing with it.
- two-point dust collection (blade guard and base) seems to work fairly well.
Overall, I recommend it. For the money, there isn't much that comes close with the features. If you are buying the MK2 they may have even sorted out the fence problems.
Negatives:
Postive:
- realtively quiet.
