AWFS 18 top blade clamp
MauriceD
5 Sep 2011
Sutton Coldfield
I have noticed that the Hegner Multicut 1 has a knurled knob as a top blade holder. I have the Axminster look-a-like, the AWFS 18 scroll saw. This has an M4 threaded grub screw for changing the top blade. Does anyone who owns a Hegner know if this knurled knob has an M4 thread so I could buy one and use it on the AWFS 18 to speed up blade clamping?
Thanks, Maurice
I've bought some M4 threaded rod and put a 90degree bend in it to form a lever, works well enough. A metre length costs about £3 . Also need a couple of nuts locked together on the thread to replace what was the head of the grub screw.
From past discussions on this forum the Hegner clamp has a fancy end that allows the blade to remain perpendicular as you tightened - quite whether it's needed? you can make up your own mind.
HTH
Brian
Hi Maurice.
You might like to also consider a very efficient clamping handle/lever which goes by various names like:
Ratchet Handle, Lever handle, Indexed Handle, Bristol Handle, Indexed Clamping Lever.
If you don't know already, this is what one looks like :
If you do a lot of blade changing or internal cuts, it will be a great help as the indexing/ratchet means you can set the lever to multiple angles to suit how you tighten the clamping pressure.
This helps maintain a constant pressure setting for different blade sizes depending where you set the lever/ratchet angle.
Knurled knobs don't have the same 'indexing' ability so in my opinion, levers are a better option.
Each to their own and just my opinion.
Hope this helps.
