Alternative to putty?
Doug71
28 Aug 2016
Yorkshire
Has anybody used this instead of putty for pointing off the front of single glazed sashes? I'm liking the idea that it can be over painted in 2 hours rather then waiting a few days for putty to harden.
https://www.reddiseals.com/product/timbaglaze-putty/
I'm making a replacement box window sash at the moment so was thinking of giving it a try on that.
Doug
You can paint linseed oil putty within 2 hours if you use linseed oil paint. Very weather resistant.
The general window problem nowadays is due to modern materials. If you avoid them you avoid the problems
I have used the timbaglaze imitation putty and yes it does work. If you cut the nozzle generously enough and give it a good angle when you're putting it on you can get close to finished results without too much work with a knife. Whether it's better than linseed based is another thing, the sashes I tried it on are still fine but it hasn't been much more than a year.
Would still take beads and pins over putty work any day of the week though.
