all rounder finish?
mike s
16 Jan 2011
epsom, surrey
up until now i have been using mylands wipe on polyurethane laquer for the majority of my projects
now i have ran out i want to know if there is an even better finish that people use that is slightly cheaper than the poly i use.
i mainly use oak and pine and for the majority of projects want a relatively glossy finish,
what should i go for?
i want something fairly quick applying and setting as i dont have the patience required to do 50 coats with sanding to one million grit in between!
i use oil occasionally but for most projects i prefer using a varnish-like finish
it doesnt have to be exterior grade, just something high quality for interior fine pieces
thanks
Have you tried Hard Wax Oil as a compromise between 'Varnish' and Plain oils.
I use chestnuts version, gloss level can be increased with multiple coats but it seems pretty robust and provides a good measure of spill resistance.
thanks chas
its about the same price as the poly
iv researched it a little and looks like just the thing
Try a wiped oil/varnish finish.
Mix 1/3 each of danish oil, polyurethane varnish and turps. Wipe on then immediately wipe off again. Allow to dry. Repeat 3 or 4 times. Easy, quick and pretty hard wearing.
