devonwoody
The lamp bulb went in the bottom oven and I could not get the glass shield off (inside the oven, to change the bulb) Nobody at AEG/Electrolux would tell me how to do it, they wanted to send an engineer (to change a light bulb, the top oven the glass cage unwinds).
It took two days to get the gen. If you have the same problem you put a screwdriver under the glass edge and lever it off. The bug.
That would have been a £70 call out charge plus the bulb which is Halogen and pricey. (£16.)
