Hi
I'm building a covered shelter in my back garden for my canoes using Square posts 150 by 150 mm set into concrete. To connect the corner posts at the ends I am intending to use half lap joints with a cross beam which will be 150 x 150 mm in cross-section and just over 2 metres long intersecting the post set into concrete at 90 degrees.
I am Using half lap joints as this will be easier to lift into place and I won't be able to manage to lift that weight of timber above the posts if I was using another joint such as mortise and tenon.
When cutting a half lap joints which direction should the grain be running in order to make the joint as strong as possible.
I'm also intending to make some diagonal braces out of 4" x 4" posts. Any suggestions on the best way to install diagonal bracing in both directions forming an X shape would be appreciated.
Ewan
Ewan
