Scarf joint alternatives with green oak
rs6mra
22 Jul 2014
Hertfordshire
I need to have a beam 150 x 150 x 6400 resting on three posts with the same dimensions.
What is my best option; half lap joints on the middle post with a couple of pegs going through the beams into the post?
I’ll hate to attempt a scarf joint and mess it up!
I thought you already had a thread on this subject. A tenon on the top of each post, with a corresponding mortice at the correct points along the beam, with braces tenoned into post and beam. Each tenon can be locked in with a drawbored peg.
Is your horizontal beam one piece or two? You could use a scarf joint to join two smaller pieces to make one beam but there are other better choices that I could draw for you if you want.
This thread is in relation to joining the beams hence me starting another
The horizontal beams are in two pieces and I have never done a scarf joint before. I have watched a couple of videos but I don’t feel comfortable. If the timber was cheap I would have attempted it.
I will have three posts on which I’ll use the M&T on the end posts a was recommended but it’s joining the two beams I’m unsure about.
There are several methods of creating a Scarf Joint. - So I looked it up on Wikipedia to save my keyboard time......https://en.wikipedia.org/wiki/Scarf_joint
The strongest one is probably = Scarf joint - Wikipedia
But you may want to avoid the steel contacting the acid in the Green Oak, because it would probably encourage unsightly rust !.....
So I looked it up on utube...=
British Building Regulations Stipulate that The MAXIMUM Unsupported Length of Any Joist or Beam
should be 4.8 metres (15 feet,8+3/4 inches Between VERTICAL Supports )
I made a 48 ft long veranda using four 12ft pieces of 8X6 (with the 8 dimension vertical, to resist any sagging) and five 6X6 posts.
The joints between the 12ft pieces were joined using a kind of scarf joint, partially locked by the tenon on each post, eg :
The joint is a slightly modified version of Figure 1 c. here: https://d-nb.info/1222809702/34
Cheers, W2S
PS I lifted all the timbers myself, using bits of scaffolding to make lifting frames. I smoothed all these timbers by hand in a morning with a Stanley No 5 handplane. I would suggest that a 12ft piece is about the maximum you would want to deal with. A telehandler could be a very useful tool - you do need to thing about the practicalities of safely manhandling these big chunks of wood (besides the technicalities of the joinery!).
The simplest way to join the beams would be a lap joint, but you can enhance this by using a slope on the vertical cuts. Used with a couple of pegs from above ( or a couple of stainless coach screws ) this addition of a slope will resist the movement of the beam up or down.
On a practical note, if you deeply knife and gauge the marked lines, you can use a chisel to pare away material on the waste side of the cut. This will give a nice shoulder to run the saw against, Apologies if I'm teaching granny to suck eggs here.
Best of luck
