A.W.Oak fire place surround
master beaver
6 Mar 2012
norfolk
hello woodworkers :) had a small job came in at work not to fancy the customer design it all for the boss ect, so i thort i post up some pics of the work
the design
the A.W.oak for the job
some bits to rip on the re saw
all the bits read to PAR
all PAR'd
colour mach and grane as best i could for the curved front
then on the spindel to do the lighting joint for glueing up
then to make the corner posts
then to grove out the panels what needed them
then marked out the curve cut out, call all to lengh ready to be put to gever, some pics of it finished just waitting for the customer to pick a finish they like
thanks for looking
lee
interesting way of grooving the boards onto the corner posts. are they just glued in place?
the aw looks quite dark.
good job though.
its how the customer wanted no pins screws just glue, the aw oak we been getting hasnt been the best of late dont no why.
alot of the timber is....
sapele ive been using alot lately moves alot with machining, even the timber yard mentioned it...
phil.p":khmv6pe0 said:
Nice oak ,nice machines, ........pineapple! I've ripped out way better fire surrounds than that!
you may of done so good for you
i can only make it how the customer wanted it
What exactly do you dislike about it? Really? Its got quite simple lines to it, maybe it could do with a couple of touches hear and there but I quite like it.
I suppose it's not really about if I like it but does the client like it. I think it looks very well made and I appreciate the OP taking time to post it so I and other can 'look and learn', as a hobbyist seeing how the pro's do something is interesting.
Mick
Write your reply...
