Morning all,
I'm trying to get to the bottom of a problem at work. Apologies for being a bit vague, I might post up more details when I've got the time to put something coherent together!
We use 110V DC motors to drive a mechanism. A ballscrew is used to convert the rotary motion into linear, and there is a mechanical load on the linear part. The motors are only used in bursts of no more than 7 seconds. On some of the circuits we have current monitoring gear that records a trace on a graph. The graph generally shows an in-rush spike, then a low-current lull for around one second while lost motion is taken up. The current then increases to a steady 2A while the load is driven, until a switch removes the feed to the motor.
Here's the thing... on two particular mechanisms, the graph trace is showing the current dropping to zero for a fraction of a second, usually during the lull / lost motion period but not always. Our supplier has put this down to spring in the mechanism. He says that as the mechanism springs away from the drive, the motor is suddenly taken off-load so the current drops. But down to zero? I'm not sure I believe it.
Any opinions?
Any opinions?
