Night Train
We all have them from time to time.
Having spent all day working on my roof I went on to my friend's recording studio where I am doing some work. I had built a double skin sound proof wall with two pairs of double doors in the centre of the wall to create a room within a room. Today I wanted to get the door latches and furniture fitted so the doors would be usable.
The double doors are rebated and fitted like a narrow airlock each pair having one bolted door and one door with a latch and handle.
I fitted the top and bottom bolts on the bolted door and adjusted the shut line with the opening door and then using masking tape I set up a centre line for the latch, strike plate and handle.
I drilled the door and fitted the latch, then drilled the holes for the handles and made sure they worked properly. I then checked alignment for the strike plate on the bolted door.
I marked around the strike plate and flushed it in to the door edge being careful to countersink the screw holes.
I shut the door and it didn't quite catch. Hmmm.
Spying through the narrowing gap as the door closed I could see that the latch was lined up with the strike plate and that the latch bolt was clicking into place but the door kept springing open.
I took everything back out and rechecked it was right, getting tired and frustrated. Everything seemed to be ok, it was all moving freely, the latch bolt fitted the strike plate and the rubber door edge seals were accounted for.
Reassembled and tried again. Still didn't stay shut.
Left the doors and tidied my tool box for a while. Got some fresh air.
Went back to try the door again, still not staying latched.
Then I noticed that I had fitted the strike plate to the edge of the bolted door and forgotten to mortise the hole in the middle of it.
The second pair of doors were simple after that little lapse.
