A Couple of Bowls From Recently Acquired Stock
Vic Perrin
10 Mar 2013
Rugeley Staffs
Hi, I was asked by a couple of members to post some photos of what I had made with the recent stock that I got from Home of Wood.
12" Elm Bowl 3" Deep & 14" Spalted Beech Bowl 4" Deep
Vic
Think they look really good, can could tell me the process u used to finish them , eg what u sanded down to and ? Wax etc. thanks.
Very nice. A little spalting looks great, to much can sometimes be overkill and take the eye away from the form.
Hi, I sanded down on the lathe using an Aminster Bowl sander going through the grits 80, 100, 120, 180, 240, 320 and 400.
I then applied 3 coats of Danish Oil leaving each coat overnight to dry.
Finally I hand polished with 3 coats of Microcrystalline wax.
Vic
Nice bowls. As a constructive criticism only, maybe try rounding the edges of the rim a bit so it give the impression that the walls are thinner. This is just personal preference though. You have certainly got the inside bottom very smooth which is something I am having difficulty mastering.
Point taken, I will try rounding the edge on the next one I turn and see how it looks
Vic
