RogerS
BT are in the process of upgrading many exchanges to handle this.
However, a few cautionary bits of advice.
It will take at least 3 days while the BT system fine tunes your line. During this time your line speed is going to be all over the place - so do not panic.
It won't work with a USB modem.
Try and avoid turning off or rebooting your router otherwise the BT equipment thinks that your line is dodgy and ratchets down your line speed (and I haven't yet found out how to get this reset). So if your mains supply has a tendency to go on/off then treat your router to an Uninterruptible Power Supply.
Once fine tuned then the BT equipment constantly monitors the line and, a s far as I can see, will tweak the line regularly..which may mean quite wide fluctuations in line speed.
After about 4 days my speed went up to about 5Mbps which isn't bad...but then I went through a lot of mains on/off cycles and now i'm back down to 356k. I'm told that I have to go through the finetuning all over again.
If your line speed hasn't given you much improvement after three/four days then it is worth switching off the router for about 30 minutes. Then turning it back on which has the result of forcing the BT equipment to reset your line and start again.
Zen website has a load of useful stuff on it.
Don't be surprised if the various speed test services get overloaded as we all try to find out what our new speed is :lol:
