 Reply
As it is not in the UK
42
98%
1
2%
User avatar
By sometimewoodworker
#1306852
A stand for a belt, disk sander
You do not have the required permissions to view the files attached to this post.
User avatar
#1307684
Storage and location solutions.
I've standardised on a few things in the workshop, the first I'm going to mention is to add French cleats to the walls and other vertical faces. The benefits for me is that when I want to change places where tools and other things are placed it is just a case of ensuring that I have a French cleat in the new location or adding one.
Since the important part of the cleat is the top 45 degree face I've standardised on a relatively narrow rail this makes better use of material. I can do this as the walls are AAC blocks so I can fix virtually anywhere. I have also standardised on Rubberwood as the cleat material as it's reasonably priced and has quite good availability.
I needed a few more of the horizontally supports , this is the style that I've adapted.
They have got a couple of 20mm holes that can have rods through them like this
