 Reply
By Doug71
#1273388
I am making a front door for a customer which has glass in the top and two panels in the bottom. The panels are flat with an ogee bead mitred around, a bit like a bolection mould but the bead only finishes flush with the face of the door. The door is accoya and the panels will be tricoya.
Do you think the bead will be okay fixed straight to the panel as there should be no movement? I would normally put a lath in the panel groove to fix the moulding to and float the panel between the mouldings but not sure if I would be gaining anything?
Building is listed so we are stuck with the design.
Hope this makes sense to somebody?
Many thanks, Doug
By RobinBHM
#1273510
Doug71 wrote:I am making a front door for a customer which has glass in the top and two panels in the bottom. The panels are flat with an ogee bead mitred around, a bit like a bolection mould but the bead only finishes flush with the face of the door. The door is accoya and the panels will be tricoya.
Many thanks, Doug
Ive always done your method.
Maybe if its tricoya the minimal movement will mean the beads can be pinned to the panel.
I think that movement in the stiles, muntin and rails might mean you end up with a gap between flat bead and those components.
By Doug71
#1273535
Thanks for the replies, sorry I wasn't very clear, must learn to post pictures.
Robin, I will stick to doing it as normal then I know there won't be any problems. It was because the one it's replacing just had the moulds nailed to ply panels that I questioned am I over engineering it.
