Reguarding removing the magnetic table be aware that for a surface grinder to operate to its full potential the table will need re-grinding everytime it is removed from the machine to ensure it is flat and parallel to the spindle.
Do not run the machine in reverse unless you want the wheel bouncing around the shop and do not adjust the speed at which the machine runs at, it has been designed and geared to rotate the wheel with a peripheral speed which matches the ideal grinding surface speed.
