Yew - should I or shouldn't I?
Unib
10 Jan 2012
Sheffield
I have a jewellery box to make for our lass's birthday in a few weeks time – I have some boards of English Yew sitting in the workshop which I've had for a few years and was wondering about using it, but, I've never used yew before – I've heard it said that it's a bit of a pig to work with. I was just reading on Lumberjocks how someone had used Pacific Yew on a project and it was a nightmare from beginning to end; not sure if its working characteristics are different to English Yew.
So, anyone have an yew based advice? Should I leave it alone and use something else or am I worrying unnecessarily? I guess super sharp chisels and low angle planes are in order to deal with tearout.
CHJ
31 Dec 2004
Cotswolds UK
Well seasoned English Yew works easily, it turns like butter so I see no reason you should have any problems.
Does not like generated friction heat but that is only a risk from finish sanding during turning. (heat stress cracks)
woodbloke
13 Apr 2006
Salisbury, UK
It's lovely stuff to work with...provided you get hold of the right bit :mrgreen: It's prone to cracking and splitting, so even if it's been in your garage for a few years, it won't necessarily be conditioned for inside the house. Low angle BU planes yes, (with a very tight mouth) but make sure the effective pitch is fairly high, around 50-55deg, so a honed bevel of around 40degish - Rob
jimi43
12 Mar 2009
Kent - the Garden of England
One of the benefits of a good old infill smoother Unib....
Yew looking at me....yew looking at ME! (sorry - couldn't resist it!)
But it does help to have a reasonable iron!....
8)
Jim
Unib
10 Jan 2012
Sheffield
Ha - don't be showing me that Jim - I've got a very itchy Ebay finger – I don't take much persuading!!
woodbloke
13 Apr 2006
Salisbury, UK
Not knocking Jim's infills (got a large Norris panel plane myself) but it's the effective pitch of the iron (and a very tight mouth) that will tame yew and that can be achieved with the outlay of a lot less sponduilicks than on a Norris smoother - Rob
jimi43
12 Mar 2009
Ah....well yes Rob...but I didn't pay much for the Slater...just keep a good eye out for these things! 8) It just happened to come with a Norris iron...quite lucky really!
I still hanker after your Norris Rob....but I will have to retire first to afford the real thing..... :mrgreen:
One day mate...one day! :wink:
Jim
woodbloke
13 Apr 2006
Salisbury, UK
Jim
It's still up for grabs Jim, but no Norris iron which I discovered recently. It doesn't get used, so is rusting away quietly to itself under the bench...bit like the Titanic really (and before anyone says, that's too big to go under the bench :mrgreen: ) - Rob
RogerP
7 Jan 2011
Gloucester
Never had a problem working English yew BUT I have had problems whilst turning the stuff with reactions to inhaling the dust and dust on the skin.! So take precautions with a very good mask and air cleaning extraction.
