Hemsby
My workshop floor is in need of attention, internal dimensions are 24x8 foot.
I intend to cover the old concrete floor with flooring grade T&G chipboard on top of 1” thick Tantalized battens, levelled & screwed to the floor. (can’t be much thicker than a 1” batten )
My intention is to lay the battens across the 8ft width spaced at a maximum of 12” centres with the 8’x2’ sheets at right angles to the battens & running parallel to the walls.
I would appreciate members thoughts as to whether the 12” centres will support the chipboard while moving my wheeled table saw & planer thicknesses and bandsaw around.
