Hi Brian,
I have the 12" version and it's a superb bit of kit: very solid, heavy and robust. The tables are very nicely flat and smoothly ground. Conversion from planer to thicknesser is quick (although swinging the tables over is best done slowly as they are b**** heavy !) Dust extraction, though not perfect, is better than most.
The finish from the four-knife cutter block is excellent. As it is a 3hp machine, I have mine on a 30 amp circuit, but I would guess that the smaller, 10" model would be OK on a standard 13 amp plug.
HTH
Paul
