Wooden Tongue & Groove Plane
DTR
11 Mar 2011
Essex
Good evening chaps & chapettes,
I recently came across an interesting wooden T&G plane. Rather than being a matched pair, this was a single plane in two halves. The "groove" side had a skate like a typical plough plane, and the "tongue" side had a shaped sole like a moulding plane. Between the two sides was a common fence. The two sides were arranged to plane in opposite directions (if that makes sense?) so that the fence would always reference from the same side of the stock.
I was very tempted to come home with it but it only came with a single "tongue" iron. The iron was wedge-shaped like a plough iron, so I imagine the "groove" side would be similar and take regular plough irons? What put me off was the availability of "tongue" irons, I have never seen any.
Has anyone ever come across something like this?
Is yours like this?
If so, this model was common in France, although the pic shows a Chapin (USA) exemplar.
Ciao,
Giuliano
DTR":ri8r79el said:
...The iron was wedge-shaped like a plough iron, so I imagine the "groove" side would be similar and take regular plough irons? What put me off was the availability of "tongue" irons, I have never seen any.
The iron of these models is different from that of English classic plough. It is tapered in thickness and grooved but has constant width from cutting edge to the other extremity.
A plough plane iron, instead, is larger and changes its width only for a couple of inches toward the cutting edge and so would not pass trough the mortise.
Hope this helps
Giuliano
Here's another:
Frustratingly, there are no markings on the body or the irons, so I can't even say which country it was from.
It's very tough - I think the whole thing is boxwood - and there is no risk of losing the matching half of the pair!
Double-ended match planes do come up on Ebay from time to time.
Stanley used to produce a metal version - 146, 147 & 148 in graduating sizes of board width.
Hope this helps
Giuliano
Hmm shame. I would have been tempted to buy it if irons were easy to come by.
Thanks for the info guys :)
Here it is mine. It's a British model from Moore - Liverpool. Goodman book dates the plane between 1828 and 1870.
I had to do some repair (a new wedge also), rust treatment for iron parts and sharpening.
Finally, I enjoyed its matching job.
p.s. do not forget the presence of two irons when you handle the plane (see plaster on my finger :mrgreen: )
Ciao
Giuliano :D
Here's mine, a 5/8" by Griffiths of Norwich; I refer to it as the "push-me pull-you plane" :)
Must confess to never using T&G, despite having a number of alternative means to make 'em. Should remedy that really, taking due note of Giuliano's advice vis-a-vis two irons first... :D
Nice planes guys and gals....!
What I find most spectacular is your attire during woodworking Giuliano!
Only guy I know who does woodworking is seriously cool Italian shirts! 8) 8) 8)
Jim
Jim
For Italians the shirt is a must in any occurence.....although by night I prefer a pajamas :mrgreen:
