John. B
My design this time.
Two pieces of 18mm ply glued together for sturdiness, some scrap hardwood (sapele in this case) a couple of squares
of MDF for the bottom slides routed to fit the lathe bed(I have a Tyme Avon)
Two coach bolts inset in the MDF under the glued rear wood block. The three arms are made from a section
of 15mm square steel from B&Q drilled and filed. The wheels are from the remains of a B&D powerfile that was scrapped.
