Krome10
Hi again
Another bathroom refit question, this one involving wood but still off topic enough for this sub forum I think
With the upcoming plumbing work and everything being drained down for it, I'm taking the opportunity to replace the boards under the tank in the loft because they have signs of woodworm... I'm hoping to use 18mm ply because it is available at B&Q where they will cut it to size for free, which will save time, hassle, and will mean I can fit it in the car! But is 18mm thick enough?
Here's some relevant info:
- The existing base is T&G floorboards and they're 20mm
- The tank spans three joists
- The joists are 150mm x 37mm. Joist centres are average 400mm apart.
- There are no walls beneath the tank. The nearest wall is a solid internal wall, which is 500mm away from the tank, to the side.
- The tank is 40 gallon / 182L actual (60 / 273 nominal)
If 18mm will be enough, it seems B&Q offer two types of ply and I wondered which is best please?
Many thanks for the help
Hardwood Plywood Board (L)2.44m (W)1.22m (T)18mm | DIY at B&Q
Hardwood Plywood Board (L)2.44m (W)1.22m (T)18mm - B&Q for all your home and garden supplies and advice on all the latest DIY trends
www.diy.com
Natural Softwood Plywood Board (L)2.44m (W)1.22m (T)18mm | DIY at B&Q
This Plywood Sheet is Furniture manufacture, construction, pre-fabricated components, base for laminating
www.diy.com
